LS1 Hotcam?
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
110 LSA
That's what I would install.
I'll have numbers on my hotcam in a couple of days for a stroker application. I'll probably wind up going with something bigger eventually, but I had it and wanted to see what it'd actually do. The previous owner of the cam/heads I'm running got 390hp/390ft. lbs. and ran 11.3 with a stock bottom end (that's what I was told anyway).
There are better cams out there but, like I said before, these cams are easy on the springs and with a set of LS6 springs will go 100k miles without needing replacement!
239/239 .570 on a 106.5 center. I'll bet that thing idles over a grand!
Cam swap requires:
Cam
Gasket/bolt kit
Springs
fluids/sealants
tools
and most importantly (TUNING).
So in my opinion, if you do not have the complete budget to do all of these at the same time, you are doing things "half ***" and you are hurting your motor.
The thing that I see here with enthusiasts ALL the time, is them doing swaps and then running the car once it is done without TUNING.
That makes me crinch everytime. I really think there should be a DO NOT DO sticky, to make the modders understand the effects of not doing things properly from the first time.
It's definitely quick, but I won't say I always feel confident with it in a race, even though I've only "lost" to an '04 cobra.
I currently have the hotcam, lts, !cats, catback, switching to MS3/heads/4.10s soon... (time to get confident).
