LS1 Hotcam?
Old Feb 7, 2006 | 10:51 AM
BLACKOUTZ28's Avatar
Default LS1 Hotcam?
Okay guys I need your help…I am thinking of getting the “LS1 Hotcam” and I have some questions.
Will the car need a tune after the install of the “Hotcam”?
What kind of power would I gain from the “Hotcam” and the mods in my signature?
Steve
Old Feb 7, 2006 | 10:53 AM
Hugger's Avatar
You will definitely need a tune. Mine would not even stay running after I installed the Hotcam. Especially with an A4. I never dynoed the car with the hotcam but I did run 11.63 at 115 mph. Hope this helps.
Old Feb 8, 2006 | 08:05 AM
Thanks for your info Hugger.
Anyone else have experience with this cam?
Old Feb 8, 2006 | 05:34 PM
dameter21's Avatar
yeah i had this cam im my 2000 z m6 it's sounds good, longtubes, ory, 4:10's
lid, i did 371 rwhp i seen 395 rwhp with my setup plus the addition of ls6 intake, pulley, throttle body, tune.
Old Feb 8, 2006 | 05:36 PM
dameter21's Avatar
i think i'm going to go with the tr 224 on a 112 on my new ss.
Old Feb 9, 2006 | 10:48 AM
SSCamaro99_3's Avatar
I have been happy with mine. I made 381 rwhp/373 rwtq on the stock tune. Mine ran ok on the stock tune, but the idle would bounce around a lot.
Old Feb 9, 2006 | 02:35 PM
RooRnZ28's Avatar
mine wouldnt idle worth a **** once i installed the hotcam... i got a mail order tune and she still struggles to stay alive once in awhile. it sounds good though and pulls a lot harder up top than stock... if you go with it, get a full blown dyno tune and it should be ok.
Old Feb 9, 2006 | 04:26 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Get that surge tuned out of it! you are probably leaving some good power on the table.
Old Feb 9, 2006 | 04:29 PM
Oscar Will's Avatar
I took my Hot Cam out after 20 miles. It made a ton of power but for an "Ol Skool Cruizer".........a little too rough at low RPM.
( I still have it in case some wise guy wants to get "whooped")
Old Feb 10, 2006 | 09:08 AM
Thanks for the info guys. The reason I had asked this question is becuase I'm going to be getting a loan to get the converter and I will have about $800 left and wasnt sure if I should get the cam or more bolt-on's. I really want the cam but I dont think I will be able to get it tuned right away.
Thanks for your help guys
Steve
Old Feb 10, 2006 | 09:53 AM
scarbrow's Avatar
what are the specs on a hotcam?
Old Feb 10, 2006 | 09:59 AM
1_Bad_LS1's Avatar
218/227 525/525 112 Lsa
Old Feb 10, 2006 | 10:35 AM
Full-Force's Avatar
mmmm, I think its
219/228
Old Feb 10, 2006 | 10:51 AM
1_Bad_LS1's Avatar
I have seen it two places listed as 217/227...
only once was it listed as a 218/228
but either way, you get the idea...
Old Feb 10, 2006 | 10:54 AM
b00sted's Avatar
I've heard it's a nice cam to go with. I'm gonna end up doing it in my z28 after I get the exhaust and intake in. Probably gonna do a full dyno tune once I've got everything in...We'll see how well it works.
Old Feb 10, 2006 | 11:55 AM
This is what my cam card reads.
Old Feb 11, 2006 | 01:47 PM
Vesper TA's Avatar
Hmmm. Strange my hotcam card reads 219/228 but it is still listed on some websites as 218/227. I wonder if they just round up on the card.
Old Feb 11, 2006 | 03:59 PM
Mike94ZLT1's Avatar
Is it possible you someone is confusing the duration specs with the LT1 hotcam? They are both ground very similar but I seem to recall the duration being off by a degree or two. I had the hotcam, once upon a time and I liked it BUT you need to get it properly tuned on a dyno, otherwise forget about it.
Old Mar 3, 2006 | 05:53 PM
Phillipm's Avatar
I think that I am seriously low on horsepower here. I have had the car tuned by two different people and do not even come close to what you guys are laying down. Hmmm. The car is a 69 camaro with an LS6, hot cam, 1 3/4 headers and 3 in. exhaust with spin tech mufflers. Can anyone have a look at this dyno and tell me if they see anything wrong right off the bat? I was thinking about changing out the hot cam to a TR224 112 but after seeing what the hot cam is capable of I think the problem lies in the tune.
Old Mar 3, 2006 | 06:22 PM
93ChevExt5.7's Avatar
Hi,
I have the LS1 hotcam along with A4, AFR205 (59cc), 6.0L intake, Edelbrock shorty headers, custom exhaust, FASTCHIP tune. The TRUCK, yes, 93 Chevy Extended Cab P/U with a 8.5" - 10 bolt, 2 piece driveshaft put down 346rwhp/365rwlbtq. Not bad if you figure a 20% drivetrain loss (which I don't think is too much to assume - in fact - I believe that's quite conservative).
Truck does lope, there is some noticeable surge, but that might be due to a poor TPS.
If your gonna do anything but stock heads, I'd opt for another cam. With my setup, I'm looking at the LG G5X2 cam - you might consider something like the G5X1, its the one I was really thinking about zeroing in on, but with the AFRs, they have springs able to handle .650 lift, and I'm told no flycutting is necessary by LG (who is going to do the work and the tune).
I think the current package I have in the truck (which has handed a SRT-4 w/mods its horns to it - beat it by about a length) is ok...especially for a 4400lb truck.
