Questions before removing heads
I am in the middle of a H/C swap and about ready to pull the heads. Does anyone drain the block to reduce the clean up? If so how?
Also on a C5 can the headers be dropped enough to access the head bolts and not remove the headers completely?
Thanks guys, Viper can you tell me about where the drain plug is? That sure would make life easier.
I have QTP headers I will try to remove the bolts on the bell housing and see if they go low enough
