Install Oil Pump And Timing Chain??
Old Feb 11, 2006 | 01:50 PM
redtail2426's Avatar
you can get just a timing chain.Im not sure what kit you are refering to,but all you need is the timing chain and oil pump if you decide to do that,no timing gears,gaskets ect.
Old Feb 11, 2006 | 02:32 PM
SLEEK00SS's Avatar
ok cool. I saw kits available from SDPC. They called it a set. LMPerformance has a comp cams set. TSP has a LS2 timing chain set.
Old Feb 11, 2006 | 02:35 PM
kossuth's Avatar
that part number is just the chain. You can reuse your stock crank and cam sprockets just fine.
Old Feb 11, 2006 | 04:23 PM
SLEEK00SS's Avatar
OK good. I just wanted to make sure that the original sprockets will be ok for the LS2 chain.
Old Mar 8, 2006 | 12:43 PM
Dirty 30's Avatar
bump on the chain? Whats the diff. between an LS1 and LS2 timing chain?
Old Mar 8, 2006 | 01:21 PM
Last Call's Avatar
TOTM: January 2007
ls2 chain is beefier. Has thicker links than the ls1.
Old Mar 8, 2006 | 03:51 PM
you2slo's Avatar
This was a great thread. It helped more than only Sleek00SS.
