Will 1.8 ratio rockers/stock cam make the exhaust sound cooler
#61
I got H-S 1.8s to take advantage of the .650 double springs and the flow of my new PP LS6 heads. Since I'm staying with the 224/224 .563/.563 112 LSA cam, it would be a shame not to take advantage of using a higher ratio rocker. This is one of those instances where it makes perfect sense to swap out the stock rockers, but every situation is different.
#62
Originally Posted by vettenuts
Is that preload at the pushrod or the adjustment nut? (How many turns?)
