Head swap tips?
Old Feb 10, 2006 | 02:44 PM
iamsickofitall's Avatar
Originally Posted by 777
First off the comment about the torque wrench being off by a little bit could spell disaster. I highly disagree. The directions are to tighten to XXlb/ft of torque. Then you need to turn them like 90 degrees and then another 90. So if you are off by a couple degrees that would be the same as being off some with the torque wrench. It's not that precise.
i'm sure the large bolts can handle it (mine did), but the small ones are a different story - my wrench had extra play in it and i ended up turning about 270 degrees extra on one of them and snap
Old Feb 11, 2006 | 12:23 AM
cowboysfan's Avatar
Originally Posted by slt200mph
YOU do not need to cut off the sharp plastic fasteners that protrude under the cowl..they are push-pull fasteners..just pull them up from the top of the cowl and than push them back down upon completion of your work uner the cowl..no need to destroy them..
this will not destroy them all u are doing is cutting the tips/sharp point off. so leave about 1/4 and you will be fine. like all/most push/pull fastners, some are easy to pull out, some will be detroyed when pulled out. I should have been more clear on this . u wont have to deal w/ this again. I see u got head off. this mostly applies to driver side, but hand does go under dash at both ends. just my .02
fuerzaws6
Old Feb 11, 2006 | 07:23 AM
slt200mph's Avatar
fuerzaws6
I've unfastened mine a number of times and they still work fine..have not replaced any yet..
Old Feb 11, 2006 | 09:18 PM
cowboysfan's Avatar
"yet" cool it works for you. buddy pulled them out and need to replace 3 of them. dont cost much, but will add up. me, "0" .
fuerzaws6
Old Mar 24, 2006 | 04:10 AM
eallanboggs's Avatar
Pulling one of the water jacket plugs in the block would help to cut down on the coolant getting all over the place. I wish I had don't that one. The wet/dry shop idea is also a good idea. If you have a compressor you can use your air nozzle to get the remaining coolant out of the bolt holes that the paper towels don't wick up. One of the last things I did was to pull the drain plug in my oil pan and I was glad I did because the first thing that came flowing out of the drain hole was coolant. It wasn't a lot, but I guess some of the coolant went into the cylinders when the heads were lifted off and got past the rings before I could soak it up with paper towels. That might be another thing to check before you turn the key.
Old Mar 24, 2006 | 04:23 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
look under the windshield above the engine, u will see those sharp plastic clips cut them off with cutters. it will save your hands.
I have never done that, and have done several head swaps. My arms don't thank me for changing valve springs while head is on the block.
Old Mar 24, 2006 | 04:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Looks like the goober method strikes again...I am willing to be that he did not come up with this idea first. He learned from a few of the best.
Old Mar 24, 2006 | 09:01 AM
JoeMack's Avatar
Here's my set up for cleaning out the bolt holes. They were pretty nasty. Cut 2 of the original bolts with a dremel to use as a tap, break parts cleaner, small hose attached to compressor to get down to the bottom of the holes (used the small red tube from a wd40 can, inserted into the clear plastic tubing, to get to the bottom of the 10 small holes) and taped everything off to keep the mess out.
Old Mar 24, 2006 | 04:56 PM
00BlackSS's Avatar
be paticent(sp) and have fun
Old Mar 24, 2006 | 08:09 PM
Hugger's Avatar
If you don't want to ruin your shop vac just take the coolant plug out of the block on the passenger side. It is directly above the starter and will drain the entire block.
Also if you leave the radiator cap on and the cooling system pressurized when you remove the plug nothing will leak out. Just take the plug out, put a bucket under the car, then take off the radiator cap and the coolant will begin to drain. No mess at all
Old Mar 24, 2006 | 09:52 PM
MOTRUBL's Avatar
What size wrench for the block plug??
Old Mar 25, 2006 | 08:57 AM
  #32
HavATampa's Avatar
I removed the block plugs when I did a head swap last year and it works well, but I was also changng out the motor mounts which makes it easier to reach the driver side plug. I had to remove the starter to remove the passenger side plug. This go around I used the Shop Vac method before removing the heads and this is the way to go. No mess, a lot less work and you don't have get under the car.
Pics and specs of the block plugs are in this thread if you still want to do it that way, not sure why though.
https://ls1tech.com/forums/generation-iii-internal-engine/335413-afr-s-fast-90-nw-90tb-poly-mounts-fast-rails-finally-done.html
Old Mar 25, 2006 | 10:05 AM
  #33
Hugger's Avatar
The block plug is an 8mm allen head bolt. Be careful taking it out since it is very easy to strip out. I am about to replace it with another type of plug that is easier to remove.
Old Mar 25, 2006 | 10:18 AM
  #34
vodas00ss's Avatar
I think a good piece of advice is to make sure you clean your deck surface thourghly before puttin on new gaskets and heads. ls1how to says to use a plastic ice scraper, this sucks. it dosent get it clean. I suggest you just use your head and be careful and get a razor blade. Be sure not to gouge the block with the blade.
Old Mar 25, 2006 | 10:59 AM
  #35
slowpoke96z28's Avatar
die grinder with a roloc disc is the fastest way to clean gasket material. be sure to put thread sealant back on the coolant plugs before you install it.
Old Mar 25, 2006 | 03:17 PM
  #36
indyboom's Avatar
hey whats the deal with the push rods? Do you always have to get longer ones? How can I tell?
Old Mar 25, 2006 | 07:36 PM
  #37
Viper's Avatar
indyboom
You can tell by measuring properly with an adjustable pushrod. Geometry and preload is what separates the big horsepower from ok HP. Well it certainly makes a difference when added with everything else.
https://ls1tech.com/forums/showthrea...light=geometry
