Am i missing anything (Cam Install)
Old Feb 8, 2006 | 08:05 PM
killaz's Avatar
Default Am i missing anything (Cam Install)
Aight guys going to install a cam in my 00 vette M6. Going to do a custome grind 236/244 .610/.620 114lsa. Im also going to upgrade to a LS6 intake, Ls2 timing chain, Underdrive Pully, Patriot Performace springs, Is there anything that im forgetting? I would like to only do this task once. lol
Thanks
Old Feb 8, 2006 | 08:25 PM
Griswold's Avatar
I would do pushrods for sure and depending on how many miles you have, the oil pump also.
Old Feb 8, 2006 | 08:50 PM
killaz's Avatar
im at 42000miles now. is the oil pump easy to do while your there?
Old Feb 8, 2006 | 08:52 PM
black_z's Avatar
The oil pump is easy to do. Yours would probably be fine though. I would definitely buy some hardened pushrods though. Do you have all the gaskets?
Old Feb 8, 2006 | 09:00 PM
killaz's Avatar
not yet. Is there a cam gasket kit i can get?
Old Feb 8, 2006 | 09:09 PM
Ωmega's Avatar
I get them from TSP. They sell the basic cam gasket kit. Plus, you need to pull the oil pump to change the chain anyway. You need to get a new oil pump pickup tube O-ring as well.
Old Feb 8, 2006 | 10:48 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I didn't change the oil pump on my '02 Z when the F13 was installed. The factory one is still holding great oil pressure. Oh yeah go with the harden pushrods like everyone has said.
Old Feb 9, 2006 | 07:42 AM
Ωmega's Avatar
He has a 2000. 01 and 02 pumps were more reliable, but not so much for 2000 and before.
Old Feb 9, 2006 | 09:14 AM
cyphur's Avatar
I'm running a Mellings pump, its holding great pressure all around. 60psi most of the time.
