5.3l Heads
Old Feb 9, 2006 | 10:15 AM
99TransAm666's Avatar
Default 5.3l Heads
My friend told me that I can get some more power if I swap out my 5.7 heads for some 5.3 heads. Is it because I raise the compression or is their another reason? And if I do get more horses by how much? Any help would be great, Thanks.
Old Feb 12, 2006 | 12:11 PM
1hardmaro2's Avatar
I am researching that now. I know it will raise compression and most after market 5.3 heads come with larger valves. I want to know if stock 5.3 heads; which have a smaller intake vavle will see any hp gains just because of compression, or will the smaller valve not make it worth it?
Old Feb 12, 2006 | 12:26 PM
PREDATOR-Z's Avatar
swapping to PORTED 5.3 heads will benefit. Stock 5.3 are too restrictive and flow less than a stock 5.7L.
The chamber size is a +. Most ported 5.3's end up at 64 cc so you can stuff a big cam if you keep the 2.00/1.55 valves, while benefiting from added compression and extra flow.
See my sig. (those are 2.04 int/1.575 exht)
Old Feb 12, 2006 | 12:30 PM
BBADWS6's Avatar
Deoending on where you get your 5.3 heads from, they can CNC the combustoin chamber to the CC you want. They start at 59cc i believe, and like predator said they are more restrictive. Get a set of decent ported 5.3s with a smaller combustion chamber and you can see some decent gains.
