What do YOU think is happening
Old Feb 12, 2006 | 03:04 PM
02WS6Bird's Avatar
tried jumping the starter again, no luck! back to autozone w/ the warranty
Old Feb 12, 2006 | 08:20 PM
02WS6Bird's Avatar
Any other ideas before this starts cosint even more money?
Old Feb 13, 2006 | 06:54 AM
King James's Avatar
You haven't answered whether or not the security light is on. Also, Mopranos mentioned wires you took out. Is it possible you messed up the the main harness doing this?
Old Feb 13, 2006 | 08:40 AM
02WS6Bird's Avatar
Only wires i took out were the ones for the A/C unit. Security light...not sure which one that is but i do not believe it is on. Check Gauges, SES, and BRAKE lights are on in the guage cluster, no others. if i remember correctly
Old Feb 13, 2006 | 09:57 AM
King James's Avatar
Security light is the orange light that says...... "SECURITY"
Old Feb 13, 2006 | 10:00 PM
02WS6Bird's Avatar
definitely not on lol. Do any of the little black boxes behind the dash have anything to do w/ the ignition?
Old Feb 14, 2006 | 10:14 PM
02WS6Bird's Avatar
Not getting power to the purple wire on the solenoid Why not?!?! When can i test this w/ the test light. I must have accidentall been getting the test light on the power cable. Starter relay is still good. But this still is not sending power to the starter to turn it over!
Old Feb 15, 2006 | 07:48 AM
02WS6Bird's Avatar
TTT everyone.
I have a new battery, new starter, so i know these arent my problems, it isnt anything mechanical. So it must be electrical somewhere.
The black boxes behind the dashj- do any of them have anything to do w/ the ignition? If so which ones? (ones similar to that of the integrated body control module but smaller)
The starter relay is still good, i put it in my trans am and it started right up. So i figure its within the sensors or the wiring. I'm not sure if the purple wire to the starter solenoid is supposed to get power but even when i crank the key there is NOTHING. I can jump start it but that is how i blew the OE starter, and i am hoping this is not going to cost any/much more $$.
Could anyone depict exactly what goes to the ignition circuit? or explain. Long explanation or short it doesn't matter i really need to get this to work!
Old Feb 15, 2006 | 03:13 PM
02WS6Bird's Avatar
TTT with any help anyone? What wires would be there to look at for the most part...colors etc. Wondering about the black boxes still, also, there is an unplugged connection w/ a black and gray wire? where would this go i cant seem to find it!
Old Feb 15, 2006 | 03:25 PM
b00sted's Avatar
Have someone turn the key while you check to see if the solinoid gets any power with a multimeter... At least you'll know if it's a wiring problem or a starter problem...If it doesn't get any power, there's probably a bad connection or mix-up somewhere.
Sounds stupid, but helped me figure out why the 69 z wouldn't crank.
Old Feb 15, 2006 | 03:33 PM
02WS6Bird's Avatar
I'm getting no power to the purple wire (solenoid wire)
Old Feb 15, 2006 | 06:42 PM
  #32
02WS6Bird's Avatar
New discovery, pulled out relay, took a wire from the battery post (+) and connected the other end to fuse box where the purple wire connects- kicked over the starter. So the problem lies within the Green, Yellow/Black, or RED wires. from what i can see
here are some progress pics...you can see the diff wires, the bypass of the safety switch and the one connection that is not connecter w/ a black/white wire and a gray wire...
PICS HERE
Old Feb 15, 2006 | 09:55 PM
  #33
FUN LS1's Avatar
Originally Posted by 02WS6Bird
I hear some sound fromt he throttle body like a dlicking/winding kind of sound.
Check the starter and connections; have someone try to turn it over while you're under looking at it. Is the sound you hear the fuel pumps, or is it the bendix missing the flywheel?
[EDIT] Doh! I hate when I post before getting to the end, and then find out I'm wrong as soon as I see my post...
Old Feb 15, 2006 | 10:10 PM
  #34
SUX2BU's Avatar
did you just put in a new master cylinder?
Old Feb 15, 2006 | 10:35 PM
  #35
n20stroker's Avatar
try unpluggin the clutch saftey swith and jumper them together, and try fire it up. also test yellow wire under dash base of steering. ign switch with a teat lamp that test lamp should light when turning key. also try switchin another relay.
Old Feb 15, 2006 | 10:38 PM
  #36
02WS6Bird's Avatar
nope stock master cyl. new slave cyl. however. I pulled the HVAC etc, radio you name it from behind the dash. Now i need to figure out whats going wrong going INTO the fust box to trigger the relay for the starter. Like i said the Purple wire sends power to the starter, but i dont know if the other 3 (RED, GREEN, YELLOW/BLACK) wires are doing there job, nor do i know what the Black/white and Gray wires are to go to under the dash (IN THE PICTURES YOU CAN SEE ME HODLING THE CONNECTOR) BUMP
Old Feb 15, 2006 | 10:39 PM
  #37
02WS6Bird's Avatar
which yellow wire are you describing since there are several in this car
Old Feb 15, 2006 | 10:41 PM
  #38
SUX2BU's Avatar
Originally Posted by redtail2426
yeah the neutral safety switch,clutch safety switch,what ever its called for the m6,if you get down and look up on the bar that holds the clutch pedal,you will see a button switch that the bar contacts when its in the resting position,and as you push down the clutch pedal,the bar releases this button switch and allows the car to start,thats why you cant start a m6 without pushing in the clutch.Be sure this switch is plugged in and working properly,you cant miss it.
This guy is kinda right but its not the "button switch that the bar contacts when its in the resting positin".
There is a BLACK rectangle looking button that the clutch pedal hits when its put to the floor. That is the safety start switch. you can kind of see it in the middle of your second pic. it has two wires coming out of it a green and a looks like pink or light purple. they have a blue cap on the connector.
you can get under the dash and hold that "button" down and try to start the car. MAKE SURE ITS NOT IN GEAR!
The reason i asked if you put a new master in is cause if you put in an adjustable master in you might have it adjusted to where when the pedal is all the way down it bottoms out before it touches that black button.
Old Feb 16, 2006 | 02:50 PM
  #39
02WS6Bird's Avatar
Well if you look at the pictures you can see it is bypassed
Where do these wires lead too (purple and green?)
Where does this wire connect to?
The connector I am talking about that is unplugged is...
(see it unplugged)
it has one black wire and one gray wire
Also does this box.... have anything to do w/ the ignition? or is it the DRL Relay?
And does this have to do the ignition? if so what wires?
Here is the fuse box w/ the starter relay
It seems to be one of 4 wires, PURPLE (which i know is sending voltage down) RED, Green, or Yellow/Black.
Old Feb 16, 2006 | 05:44 PM
  #40
SUX2BU's Avatar
i bet your little bypass wiring is whats messing it up. undo it put it back the way its suppossed to be and see if it works.
