What do YOU think is happening
Old Feb 16, 2006 | 10:09 PM
  #41
02WS6Bird's Avatar
Originally Posted by SUX2BU
i bet your little bypass wiring is whats messing it up. undo it put it back the way its suppossed to be and see if it works.
It didnt do anything before the bypass either even when i pushed it in by hand
Old Feb 17, 2006 | 09:18 AM
  #42
02WS6Bird's Avatar
any other takes? Is that one pic of the DRL Relay? etc what else has to do w/ the ignition.
Old Feb 17, 2006 | 11:00 AM
  #43
SUX2BU's Avatar
What all exactly did you cut out?
Old Feb 17, 2006 | 08:00 PM
  #44
02WS6Bird's Avatar
What do you mean? the only cut wires are the Green and Purple to the clutch safety swtich. I took out the entire heating/cooling system
Old Feb 17, 2006 | 08:19 PM
  #45
SUX2BU's Avatar
oh i thought you cut abunch of wires or took out some little black box.
Old Feb 17, 2006 | 11:11 PM
  #46
02WS6Bird's Avatar
ok GOOD NEWS ITS ALIVE... Problem is, its one of the wires to the starter relay...
the Yellow/Black one. Where does this go from the fuse box?
Old Feb 19, 2006 | 08:36 AM
  #47
02WS6Bird's Avatar
Anybody know wherethis wire leads to... The Yellow/Black wire from the starter relay in the fuse box
(the yellow one you see)
Old Feb 19, 2006 | 09:42 AM
  #48
02WS6Bird's Avatar
ttt.....
Old Feb 19, 2006 | 08:15 PM
  #49
ShevrolayZ28's Avatar
From the schematic, it looks like the yellow/black is connected to the purple/white, which in turn goes to the clutch switch.
Is there any chance you can hook the clutch switch back up the way it was? I mean, what's the advantage of not having it? Surely the car is much safer with it funcional.
Like the others have mentioned, I think your problems began with the attempted bypass of that switch.
Old Feb 19, 2006 | 09:29 PM
  #50
02WS6Bird's Avatar
did this prior to the clutch safety switch bypass...thats why i didnt think that was it... the wire doesnt get voltage or anything when turning the key...the one that does react when the kkey is turned is the GREEN wire- this is why i thought the green wire was connected to the clutch safety switch
Old Feb 19, 2006 | 11:29 PM
  #51
SUX2BU's Avatar
You have to know how the wiring in these cars works before you just start bypassing stuff. the yellow/black wire is the signal wire to kick on the starter. it probably comes from the body control module.
You do know that the clutch pedal has two switches on it. one that is triggered when its to the floor and one that is triggered when its at the top. i bet the body control module sees that they are both triggered at the same time (due to your "bypass") and thats why its not starting. there are quite a few things involved to actually get the starter working . security system, body control module and stuff like that.
Old Feb 20, 2006 | 12:07 AM
  #52
02WS6Bird's Avatar
Which sensor is the BCM?
Is it this one?
Or is it the one connected to the Doors and locks?
Like i stated if the fuse box @ the Yellow/Black wires connection to the relay is made into a GROUND the car will start-
Old Feb 20, 2006 | 01:48 AM
  #53
SUX2BU's Avatar
Thats not the BCM. the BCM is a bigger box all the way on the passenger side by the glove box.
Yeah thats how the comuter works. it grounds out the signal wire to make the relay work.
Old Feb 20, 2006 | 11:10 AM
  #54
02WS6Bird's Avatar
ITS ALIVE!!!!! It had to do w/ a plug in the BCM the drivers side plug wasnt in all the way!!!! Wohooo thanks everyone
Old Feb 20, 2006 | 11:27 AM
  #55
SUX2BU's Avatar
you owe me $5.
Old Feb 20, 2006 | 09:13 PM
  #56
02WS6Bird's Avatar
you owe me $5.
LoL, if only i had $5 lol
