408 is alive guys!! Video of startup inside...
Old Feb 10, 2006 | 08:34 AM
gtodoug's Avatar
Default 408 is alive guys!! Video of startup inside...
Well, it's kind of funny 20 months ago I was the biggest import gearhead you could think of. I bought my GTO cause I worked at a Pontiac dealership and wanted a new car and reliable transportation. I'd never heard of the LS1 nor what they were cable of.
Fast forward to present day and with the help of this forum and ls1gto and some of the best in the business(Ed Curtis,Tony Mamo, Cary from et, and Bryan from LME) my car finally came to life.
We started it up yesterday without an issue. The car doesn't want to hold an idle. We adjusted the rpms to 1100 and it will hold there. I'm tuning it myself so I'll get it sorted out today. I'll be tuning the car in SD mode and will have dyno numbers for you guys soon. I wanted to tell all of you thank you for helping me piece this car together. Many people had a hand in it as I'm no engine builder. Enjoy the vid, and I'll repost the specs of the motor as well in case you missed some of my other threads
http://media.putfile.com/408-Startup-vid
Setup:
LME built: 408
• 6.0L iron block blue printed and assembled opened up to 4.03” bore
• Callies Racemaster 4.0” crankshaft
• 6.125” Callies Compstar H-beam rods Wiseco nitrous forged pistons with valve reliefs(flattops, 8cc rev. dome, 32cc dish)
• Compression Ratio setup at 11.84:1
• .39 quench
• Childs and Albert dura moly rings
• Federal Mogal 152M main bearings
• Clevite cb663H rod bearings
• Dura bond cam bearings
• ARP main studs
• ARP head studs
• Morel Hyd. Roller lifters
• Cometic head gaskets w/ compressed gasket thickness at .051
• ET Performance 11* 245cc heads
• ET heads have: 2.08”/1.60” valves and 61cc chamber volume
• AFR Velocity ported FAST 90mm intake mainifold
• 90mm Nick Willaims TB
• Jethot coated Kooks 1 7/8” headers w/ no cats
• Custom EDC cam(256/260 .660/.643 114LSA)
Dyno results soon to come.
Old Feb 10, 2006 | 08:36 AM
DAPSUPRSLO's Avatar
Can't see the video at work but damn, that's a lot of cam. What are you planning on spinning that thing too?
Old Feb 10, 2006 | 08:41 AM
beardWS6's Avatar
Man, that sounded sweet! I couldn`t go with as big of a cam. Mine being A4 would have killed me. Almost everything else is the same as yours. We got my port LS90 back and there bolting it in right now. I can`t wait. Im going to take some pics today! I`m just about to bust a nut. You have got to be feeling the same!
Old Feb 10, 2006 | 08:58 AM
gtodoug's Avatar
It sure sounds like alot of cam too. I'm looking for a plastic surgeon as we speak to get the smile removed from my face. LOL
Dougie
Old Feb 10, 2006 | 10:19 AM
Patrick B's Avatar
GTODOUG, That set up looks awesome. I am going to basically build one for my camaro just like yours. I was wondering what oil pump you are running, and what gas you are going to use, 93 octane or 100 octane? I was wondering what format your video was becauseI can not open it? Thanks
Patrick
Old Feb 10, 2006 | 10:24 AM
1Bad RamAir's Avatar
congrats on the setup. sounds bad azz. I should have my 408 done very soon. Can't wait to see your dyno results.
Old Feb 10, 2006 | 04:44 PM
obZidian's Avatar
DOUG, you copycat!!!!
Looks awesome mang!!! Cant wait to see it in person!!!
congrates!!!
Old Feb 10, 2006 | 05:06 PM
Armageddon's Avatar
...with cheese.
Sounds good bud
Old Feb 10, 2006 | 05:38 PM
Mike94ZLT1's Avatar
Looks good, sounds GREAT, but WHY THE HELL DID YOU PUT A Y PIPE ON IT?!
