Map sensor damaged by backfire?
Old Feb 10, 2006 | 09:01 PM
ChucksZ06's Avatar
Default Map sensor damaged by backfire?
I have read that the Map sensor can be ruined by a backfire in the intake. Is this true. If damaged would the engine start with the MAP sensor not working?
Old Feb 11, 2006 | 12:44 AM
SILVERZZ28's Avatar
Yes this could and has damged MAP,MAF sensors. You will get a DTC if it is bad.
