Rod Bolt Hitting Oil Pan F-Body !!!!!!
Originally Posted by Ferocity02
I wouldn't grind the bolt because of strength issues. The small amount of weight removed from the bolt by grinding it is not enough to throw off the balance.
ive NEVER seen a rod bolt failure from grinding the head of the bolt/screw within reason.
