short or long block
I'm pretty sure all '98's came with long blocks, but I could be wrong
Not sure if anyone here will be able to answer that question for you, but I bet if you go to www.ls1.com someone there "may" know
Let us know when you find out as I'm sure there are some folks here who'd also like to know
if theres any one that know let me know thnx, im planning on gettin a 427 based on the gm 6.0 block but its a short block would it make a difference if i get it and i currently have a long block?
Originally Posted by themack56
im wodering what camaros came with. a long block or short, maybe dum question but i need to know, my car is a 98 z28
Im not laughing at the question, everyone someday asks questions we dont know answers to...
But the answers in here.... (SLowETz)
AHAHAHAHAHAHAHAHAHAHAHAHAA!!!!!!!!!!!!!!!!!!!!!!!! !
But Id run the long block, I hear girls are into them more...
i'll put my money on a long block...
and your talking about a 427.......my advice is GO CRAZY with the search button, and hope to hear from you in a few weeks...
you have a lot to learn.....as we all once did ( i still do)
well, i never intended for myself to do the job, but i did intend on buyin all the parts, and thats why im asking if a short block 427 will fit in place
dont go with long blocks .. definitely you will have clearance issues .. stock blocks are LONGBLOCKS from factory and they are 346 not 427 .. u can imagine a long block plus extra cubes it will definitely hit every street hump .. short block all the way
P.S u cant lower ur car with the nasty longs
We're still not on the right page
Yeah.... I was hoping you weren't going to say you were doing the work
Listen.... before you do this, it would GREATLY benifit you to take some time and do some real research. Hate to see your shop do you wrong thinking you won't know better.
Shortblock = block, pistons, rods, wrist pins, crank/reluctor, main caps/studs, bearings, oil pump, cam, timing chain/gears, and in some cases, the oilpan, front/rear covers all of which are assembled by(usually)a competent engine builder.
Longblock = all of the above PLUS heads w/valves, retainers, springs, guides, push rods, rocker arms.
Please do some research before venturing any further.
This endever WILL be expensive.
Good luck!
*EDIT* Sorry guys.... just couldn't keep it up and sleep tonight.
will my current pcm control the short 427?
Dude..... your not ready to even think about the pcm. Short answer: YES & NO
Search "LONGBLOCK" pleeeaze
