Preparing to educate myself
20) When you're looking at a cam spec card and you see open at 7 degrees BTDC, is that 7 cam degrees or 7 crank degrees?
21) Just to verify, 90 degrees on the cam is a single stroke while 180 degrees on the crank is a single stroke. Therefore, if you wanted to have an even exactly half-way through a stroke (just as an example) the event would be at 45 cam degrees ATDC (again, just for an example) or 90 crank degrees ATDC. Right?
