Duration measure
Old Feb 15, 2006 | 09:32 AM
badaSS346's Avatar
Default Duration measure
Is there anyway to measure duration on a cam that us already installed in a car?
Old Feb 15, 2006 | 09:36 AM
SideStep's Avatar
Yes, get a degree wheel (and kit). You will have to yank the water pump, crank pulley, driver side valve cover. I am not sure about the timing-chain cover... I think that is all... You can download the instructions from CompCams web site...
OR
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Start with post #10
Old Feb 15, 2006 | 11:35 AM
iamsickofitall's Avatar
nope - you would have to bring it to a shop that can cam doctor it, unless you have the serial number - then you can call the manufacturer and find out the specs
