tr224 w/o longtubes
maybe I should just do nitrous....price would prob be about the same
The cheater may be a better alternative. If you want a little more overlap and power have them grind it on a 115 LSA with a 114 ICL.
Ferocity: how long did you run the cam with stock manifolds & cats? How was the tuning for idle and low rpm (below 1500 rpm) cruising? I'm curious how that much overlap does with stock manifolds. I've been looking at limiting overlap at .05 with stock manifolds to -8 to -10
Always try to keep the big picture in mind, how you want your car to perform and how you will use the car.
Intake, heads, cam, and headers all work together toward the end result. They should be matched to optimize your combo, and your $.
My understanding is that the tr224 is not the best choice with stock manifolds, and the CheatR is not the best choice for a car with LT's.
Measure twice, cut once.
Same with MN. We can only drive 7 months out of the year though.
NW Connecticut is bout 8 months outta the year.. not as cold as MN tho.. you guys man I don't know how you do it!
If I was in your position, I'd go n2o. The only reason I'm going h/c is because I screwed up my head
