All Pro heads
Old Feb 17, 2006 | 04:44 PM
billiardcue's Avatar
Default All Pro heads
Has anyone used the All Pro head?
I am building a 408 cid motor and looking for options for heads.
Old Feb 17, 2006 | 05:49 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Tell me these arent those ones on E-bay....
Old Feb 17, 2006 | 08:11 PM
Beast96Z's Avatar
All pro's are more for the all out forced induction guys. Large port volumes and low flow tend to steer the N/A guys away from them. They can however be heavily worked for the FI guys. I'd look into ET or AFR if I were you.
Old Feb 18, 2006 | 12:13 AM
Brandon Boomhauer's Avatar
Check out W2W on the All Pro's, they used them on Roofer Dave's car, and a couple other project cars I believe.
I suggest W2W as thats the only shop that I know of that has messed with the heads very much.
Old Feb 18, 2006 | 12:22 AM
DOC OTIS's Avatar
I have a set for my 427. I should have some N/A and N2O dyno numbers and track times with in the next month or so.
Old Feb 18, 2006 | 10:10 AM
Richard@WCCH's Avatar
We're working on a CNC program for All Pro's 13º LSW cylinder head. This head has a rectangular intake runner similar to the LS7 head. The target flow for the intakes are 390-400cfm and 250-260cfm for the exhaust. It will require it's own intake manifold as the ports are taller than the LS7 heads. This head will make an excellent hard core racing head. The first program is designed for 4.125" or larger bores. We're also working on a smaller valve version for the 4.00" bore engines. When comparing the LSW head to the LS7, the All Pro head has much more material in the critical areas including the rocker boss area.
All Pro's cathedral port heads are an excellent choice for 408 street engines. They're capable of 330+cfm of intake flow and 230cfm of exhaust flow.
Richard
Old Feb 18, 2006 | 11:06 AM
Holy **** Richard, thats some good #s, be sure and post up when ya get some ports finished.
Old Feb 18, 2006 | 08:59 PM
DOC OTIS's Avatar
My 15 degree All Pro's flowed 338 on the intake and 245 on the exhaust side at .700 using a 2.1 intake valve and a 1.6 exhaust valve. That should help me move some exhaust out when I'm on the jug
Old Feb 18, 2006 | 09:48 PM
JZ'sTA's Avatar
Not much better then AFR's or ETP's, and I bet these cost nearly 1000 more.
Old Feb 19, 2006 | 11:52 AM
DOC OTIS's Avatar
Well when I ordered these you could not get either of those. Figured I would get some response like that, let's just what and see what the track numbers look like dyno/flow numbers are gay
