Help: Car wont idle with new cam....
I never have before (used an email tuner) but he is coming to a dyno day in April so he said he would make any tweaks in person. I dont consider the car not running a "tweak" though......
So the tune is way off and you have to wait till April!I know Akron is way up north but I thought their was a place down south by Dayton/Columbus area that tuned ls1's.Its been so long.I used to live in Troy years ago,but cant remember if there's a place close to you.I'd check around to see if theirs a closer tuner.
The tuner that email tuned it looked at the logs i sent him and the timing is jumping all over the place at idle. I mean a ridiculous amount. He told me to do a crank relearn with my EFIlive software but the car is still doing the same thing(not idling when warm) and the timing is still all over the place. All other sensors look fine. He is reflashing another PCM to see if there is just a problem with mine.....
I think it was between 70 and 100 if i am not mistaken. Not sure off hand..
The timing jumps around 10-12 degrees! That shouldnt be normal.
