how to check pushrod length?
Pushrod checking is about the middle of the document.
Install an adjustable PR initially set too small (makes sure cam is on the basecircle of the lobe you are checking)
Bolt down the factory rockers....
Set the adjustable pushrod to zero lash and remove
Measure pushrod, then add .050-.100 to that figure which now represents your pushrod preload into the lifter and the total length of the pushrod your engine requires. This is obviously quickie instructions for a factory rocker arm set-up (pedastal mount).
How do you get your fingers in there to turn the adjustable portion once the rockers are torqued down?
