Is this lifter bad??? 56K Beware!!!
Old Feb 24, 2006 | 09:06 AM
  #61
GuitsBoy's Avatar
Originally Posted by 1fastWS6
I'll add this in regard to cam lobe 'smoothness'....I just replaced the solid roller in my BBC because several lobes had major pitting. Sent it back to the MFG and they replaced it stating it may or may not have been a bad heat treat on the core. The lifters look PERFECT still......no wear at all on the rollers. Prior to this incident, I would have thought surely the severity of the pitting would have chewed thru the rollers on the lifters.....and.....the springs I'm running are 250# seat / 825# open!
Perhaps the hardening on the rollers was greater than the heat treat on the cam in your case, so the rollers survived. Now if the two were close to equal, you culd get the repeated chewing up of lifter rollers I had in my case.
Old Feb 25, 2006 | 05:18 PM
  #62
mattsls1's Avatar
Any updates? My f13 cam and lifters **** on me. Here are pics. I have bad pitting
Old Feb 25, 2006 | 07:43 PM
  #63
HavATampa's Avatar
Good grief! And the common denominator here is .......
Old Feb 25, 2006 | 08:04 PM
  #64
GuitsBoy's Avatar
Yeah, but I get ripped on if I badmouth the cam. After seeing how smooth my new comp grind is, I truly believe it has something to do with the texture of the cam motion grind. Even now after 12K miles on my now useless f13, you can still see the tooling marks on the lobes. Dont get me wrong, i loved this cam while i was running it, but im starting to see way too many futral cams with lifters getting chewed up. Its not limited to the futral cams by any stretch, but if you look, youll see its the majority. I truly hope futral can remedy the situation cause theyve got a great cam profile with the f-13.
Old Feb 25, 2006 | 10:08 PM
  #65
mattsls1's Avatar
Mine went out around 14k miles
How can I find out if it's my cam or what that caused the damage?
Should I ask Futral if they are willing to look at the cam or have someone else do that?
Oh and my springs are manley duals .650 lift
Old Feb 26, 2006 | 10:53 AM
  #66
vettenuts's Avatar
What RPM are you guys turning with these cams?
Old Feb 26, 2006 | 01:04 PM
  #67
SideStep's Avatar
7400
Old Feb 26, 2006 | 05:24 PM
  #68
mattsls1's Avatar
only 6500 rpms with stock heads.
I bought my cam last year during the group purchase.
Old Feb 26, 2006 | 05:37 PM
  #69
pdd's Avatar
pdd
WOW, ill have to check my lifters while the heads are off as ive been running futural cams for the last few years. good luck with the fix sidestep. waiting for your results with the new cam. mine won't be up and running till spring
Old Feb 26, 2006 | 08:16 PM
  #70
GuitsBoy's Avatar
I had a 6800 rev limit, which I only came close to once. I had only seen my 6400 shift light come on maybe two dozen times with that cam.
Old Feb 26, 2006 | 08:35 PM
  #71
SideStep's Avatar
Cam is in, waiting for lifters to put this beast back together... Have you at least started yours yet???
Old Feb 26, 2006 | 08:39 PM
  #72
GuitsBoy's Avatar
I just put my **** back togather and took her for a ride tonight. Been without a daily driver for 3 weeks, of which ive been working in the brutal cold. Damn im glad thats over. Now if only my new HPTuners would ship so I could tune her!
Old Feb 27, 2006 | 08:28 AM
  #73
Cstraub's Avatar
Morel has the lifters. They are going to have their lab look at the lifters and they are going to send them off to an OEM lifter mfg for analysis. This may take a couple of weeks but I will keep you posted.
Old Feb 27, 2006 | 11:04 AM
  #74
mattsls1's Avatar
Good deal. I'll be waiting.
Old Feb 28, 2006 | 11:30 AM
  #75
vettenuts's Avatar
Will these results be posted in this thread?
Old Feb 28, 2006 | 11:40 AM
  #76
SideStep's Avatar
Yes, I will see that the results, good, bad, or ugly get posted.
I am a little concerned after talking with a few others that the results might be seen as biased since a neutral evaluator is not being used... with all respect for cstraub for stepping and looking into this for us...
Old Feb 28, 2006 | 03:22 PM
  #77
mattsls1's Avatar
So are you guys switching to ls2 trays just in case from now on?
Old Feb 28, 2006 | 03:33 PM
  #78
SideStep's Avatar
Some have, some have not.. Mine look straight and are not the "mystery" #10 casting....
Old Feb 28, 2006 | 04:06 PM
  #79
mattsls1's Avatar
I'm thinking the same thing. What cam did you have in your car?
I'm anxious for the results.
Why does my lifter look so bad compared to all the pics in this thread?
Old Mar 2, 2006 | 09:29 AM
  #80
Cstraub's Avatar
Morel will fax a copy of the report to me from the testing lab. Sidestep you can come over and read it and post a picture or scanned image of the report on this site for everyone to read. That's all I can do. If anyone else wants to pay for the testing of the lifters then they can post their results as well.
