correct rod and piston size on ls1?
Old Feb 22, 2006 | 01:36 PM
lowchevy2go's Avatar
Default correct rod and piston size on ls1?
what is the correct rod and piston size for a stock ls1. I am trying to upgrade and there a million different sizes. thanx
Old Feb 22, 2006 | 01:46 PM
NemeSS's Avatar
rod length 6.098
bore size 3.898-3.900
piston compressionn height/distance 1.338-1.339
-.007-.008 out the hole
Old Feb 22, 2006 | 04:29 PM
Demon SS's Avatar
while the above information is correct, most folks use a 6.125 rod and a 3.905 piston when upgrading the stock aluminum short block
Old Feb 23, 2006 | 02:07 AM
should i have any clearence problems with a MS3 and 241 heads..unmilled
Old Feb 23, 2006 | 05:56 AM
GuitsBoy's Avatar
No, the magic stick should clear the pistons in an otherwise stock application.
Old Feb 23, 2006 | 01:08 PM
92zcamaroperson's Avatar
what power range n/a is the stock rotating assembly with arp rod bolts and main cap bolts good for reliably? In other words if someones power goal is less than 450 rear wheel n/a is it worth upgrading pistons and rods? Even with a 100 shot on top of that it should hold it all just fine shouldnt it?
Old Feb 23, 2006 | 01:34 PM
GuitsBoy's Avatar
450 HP is fine on the stock shortblock using ARP harware. A hundred shot on top of that is pushing it, but chances are that itll hold. Pistons will fail first followed by rods. The crank and block will hold a ton of power, however the heads might lift.
Old Feb 23, 2006 | 03:11 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
Pistons will be the 1st to go.
