I'm F*****
Detroitmuscle - As others mentioned you should install some new plugs just to make sure. Might as well try your old plug wires while you're at it.
When coil pacs are on wrong the car back fires.
you swapped out your old coils and put in a set that does work or have definite proof that work and you get NO backfire. Well, that should be a indication that you might have your problem. A soiled plug will not hit, it might spark a bit but not enough for a clean combustion of the fuel/air mixture.
Also, it was mentioned that your PR might be an issue, not to mention that a lifter unloaded will not be helpful at all.
Get those plugs swapped. Also try your new set of wires (your old set actually). A good set of msd wires aren't that expensive and worth the cashola. See what she will do with the new coils. You can do a leakdown test but hold until nothing else works..
good luck, im in some trouble too brotha so you getting her started will gelp me out a whole lot!!!
