MTI Heads and Cam???
I am thinking about putting MTI's Stage 2e ported heads, x1 cam 230/227 .592/.571 112, Fast 90mm intake, fast 90mm tb, Mti underdrive pulley, qtp or kooks lt headers with bassani true dual exhaust. Heads are going to be fully preped with vavle the hole 9yrds! Questions 1.Am i going to need to mod the fuel system i.e injectors, maf, and fuel pump?If so What to what? 2. how aggressive is this set up really going to be? 3. What kind of horsepower with this make?? Thanks guys Really Lokk forward to your responses Sincerely josh B P.s It going on a 02 ss, m6 with 6800miles on it
Fuel pump and MAF are fine. Injectors will probably be fine. When MTI dynos the car you can measure the injector pulsewidth and see if you need to upgrade to SVO 30lb injectors.
Your ride will be transformed.
