forge my crank?
Old Feb 28, 2006 | 08:25 AM
98transguy's Avatar
Arrow forge my crank?
hey guys need your opinion on something. thinking about forging my rods and pistons. should i go ahead and get the crank forged also. doing this while getting a lot of things installed(for boost in the future). also if i do get the forged crank should i go ahead and get it with some increased stroke to increase the cubic inches. thanks for opinions.
Old Feb 28, 2006 | 10:28 AM
Nasty N8's Avatar
A stroked crank is great for added power. but what are your plans with the car? What do you want out of it? and what kinda budget do you have? All things to consider when doing the build.
Nate
Old Feb 28, 2006 | 04:25 PM
MiaSSmaro98's Avatar
im on the same process as well.dont know if to forged the crank or not
Old Feb 28, 2006 | 04:53 PM
98transguy's Avatar
what i want in the end is a mid 10 second or lower car , something that is not just a race only car.budget not an issure
Old Feb 28, 2006 | 05:26 PM
67Ranger's Avatar
if you are gonna get a forged crank, it would be silly not go get a longer stroke too. As for strength, the stock crank is fine for pretty much anything you will throw at it. I believe up to 900hp or so, if not more.
Old Mar 9, 2006 | 12:04 PM
stock crank all the way
Old Mar 9, 2006 | 07:23 PM
Jimmy P's Avatar
If budget is not an issue you should get a stroked LS2. You will regret it later. I have a forged 347 and I should of spent a little more and went with a stroker setup.
Old Mar 9, 2006 | 09:21 PM
wats the point of going stroker?
Old Mar 10, 2006 | 01:47 PM
CorvetteC6_R's Avatar
More displacement= More Power
Old Mar 10, 2006 | 01:54 PM
freakynipples69's Avatar
Yeah if money is not an issue, LS2 stroker all the way.
Old Mar 12, 2006 | 06:04 PM
so wat displacement will a 347 ls1 be after a 4 inch stroke witht stock size rods?and can it be stroke but low compression?
Old Mar 12, 2006 | 06:21 PM
1999TransamWs6's Avatar
yes you can still have low compression the stroke does not effect the compression like head gaskets, pistons and heads do.
Old Mar 12, 2006 | 06:32 PM
so lets say a low compression ls1 9to1 on 66 heads stock stroke how will i know wat pistons to get on a stroker lets see 383?and how much power will i have by having the same compression but on a stroker?
