flow numbers for ported 98 heads
Old Feb 28, 2006 | 11:13 AM
curtisad's Avatar
Default flow numbers for ported 98 heads
max flow for the intake is 293 and the exhaust is 202.......what does that mean exactely? How does this translate into HP and Torque??
Old Feb 28, 2006 | 11:19 AM
PREDATOR-Z's Avatar
That doesn't mean much, but if those measurements are at .600, your exhaust flow is poor
Old Feb 28, 2006 | 11:44 AM
curtisad's Avatar
I am going with a Voodoo cam 222/226 .568 with 113 separation
Old Feb 28, 2006 | 01:59 PM
KRK's Avatar
KRK
Default Flow #'s
Stock LS1 Heads - as published
.100 .200 .300 .400 .500 .550 .600
Intake 67 122 178 215 219 223 227
Exhaust 52 97 133 156 170 176 180
Ported LS1 Heads w/ 2.02's & 1.57's - as tested by AFR
Intake -- 132 195 240 283 296 227
Exhaust -- 120 171 200 217 -- 224
Stock LS6 Heads - as published
Intake 62 126 184 224 251 256 257
Exhaust 57 108 143 163 176 180 183
Your #s are quite an improvement over stock... if your #'s are at .600, then the exhaust is somewhat on the low side, but still improved. And as you can see, you are out-flowing stock LS6 heads, with which alot of people are making big power. With that cam selection, you will still see significant increases in perfomance.
Old Feb 28, 2006 | 02:13 PM
777's Avatar
777
Those ported heads sure do drop off at .600 lift
