Metal shavings in engine
I didn't realize that you had to pull the head off to flycut the piston.
I figured to do it right you had to completely disassemble the entire engine and flycut the pistons on an end mill.
Hmmmm.....did someone use a dremel tool???
http://www.ihearyou.com/~tony/pictures/flycut/
It just bent all the valves though.
Roughly how much do you think it would cost to have this fixed professionally?
