A bunch of Morel Lifter Questions
1. How quiet are these lifters compared to stock at the recommended 0.030 preload?
2. What preload are you running?
3. The recommended preload is 0.030 hot, what are the consequences of running more preload, for instance 0.060?
4. What needs to be done for installation? (Clean them with what, soak in oil, pre-lube, etc.) Note that I don't want to pump them hard by packing with oil so it messes up my rocker adjustment.
5. Any other installation tips appreciated.
Thanks.
Thanks.
Morel recommends .030".
Plunger movement is a total of around .143". All you will be doing is sacrificing a little power.
Soak in oil for at least 8 hours. Good idea to take finger and roll rollers while submerged in oil.
Just enjoy...
