biggest cid using the stock block??
Old Mar 5, 2006 | 08:33 PM
30th t/a's Avatar
Default biggest cid using the stock block??
first i did a search and you guys know the search isnt working the way it should sooo...
my uncle wants to use the stock block and make a large stroker. i know you can make a 382 from just a stroker kit and some machine work but can you bore it out and use sleeves and go bigger than a 382?? are using sleeves a ok idea??
would you guys recommend this over buying a 402 or 408 assembled shortblock?
thanks
Old Mar 5, 2006 | 09:15 PM
calongo_SS's Avatar
you can stroke to 396 i believe (not recomended), but to get a bigger bore, you have to resleeve. LS2 402 assembled shortblocks are not that expwnsive.
Old Mar 6, 2006 | 05:22 AM
30th t/a's Avatar
ttttt
Old Mar 6, 2006 | 08:25 AM
Quick Carl's Avatar
The stock bore with the 4.0" stroke crank is about as far as you want to go on a stock block (382-383). As for sleeving to go larger, It all depends on who installs them. If your sleeving and buying a crank, go with the 427" set-up.
Old Mar 6, 2006 | 10:10 AM
PREDATOR-Z's Avatar
Race Engine Devellopment (RED) and Steve D. is the man to talk to for any sleeving of blocks >>>>>>>sponsor.
http://www.raceenginedevelopment.com...4927/index.htm
