408ci stripped crank threds!!!!!!
i think somewhere near the beginning. i think like 1/2 inch into the threads.. i was thinking of getting a tap that is m16x2.0 and try re-threading the bad threads hoping the bolt will grab good threads again and go all the way in..
hey bro what is this mcmaster carr?? by the way If i get to the point that i need to tap the threads again your suggesting using #20 drill, and tap 47?
Thos numbers were prices. Youll need a M16x2 helicoil tap (not a regular 16x2 tap) then youll also need the recommended M16.5 drill.
i made a setup like this using parts from mcmaster carr for like $20. it works great.
I worked on it for seriously 3-4 weeks on/off and in the end I ended up drilling out the threads and retapping them.
by any chance do you remember what size tap and drill bit you used?? by the way what type of bolt did you end up using? high quality or what
i know the fustration now, i never thought this would happen to me..
