ramp rates...mild vs aggressive
secondly I believe I want the high lift versions of these in the 550ish range.
What I read in the cam selection guide that you get more power under the curve with the aggressive lobe but is in notable?
does one lope harder than the other (sound wise)
I assume the aggressive lobes are harder on the rest of the valve train?
I was hoping to use the 03 ls6 springs with my combination I think these are good to 570 lift but I assume that would be on the XE (mild) lobes.
a 218/220 - .550/.550 was recommended to me
Thanks
Dave
Take a look at the Vinci/Crane cams for your 5.3
They have grinds with similar #s you are asking about. And yes faster ramps do produce more power under the curve.
Are the Vinci cams a mild or aggressive lobe? I have looked at these before and liked them however I really want to find a used one to save a few bucks.
