Rhoads Lifters are here!
They will be loader but they defintely worked I was running a 292 comp grind on an old monza. They worked great. Im glad they came out with a lifter for the Ls1/6 application. Yes like hugger said, i was also having surgin and stallign problems at idle, that is all gone now, car fires right up, holds idle! soo far no problems
ant the other thing, yes u will have to deal with teh sewing machine sound, but i can def do that b/c the driveability is 485348975 times better now!
Check my old thread out, I summarize a bit. The article isn't online though.
Thanks
ed
firebird455@gmail.com
i know im asking alot
thanks
ed
hmmm 1158 says its for gen 1 caddy's
http://store.summitracing.com/partde...&view=32&N=115
1728 says for ls based cars...
On the small cams you will get more torque big cams more low end drivability...so you get a 224/224 .591 lift for example...your low end should be much improved because the lifters take 10 deg below 3000 and few thousand of lift, so if your in traffic or stop light to stoplight your full duration isnt present on idle, you'd be at like 214/214 with lift at .581..
Tiger thats the old number summit has. give rhoads a call and they'll tell you what you need
Summitt
Rhoads (look at bottom)
