PCV Valve breather?
Just do it and ditch the complete system and get a breather , I had done it from 2 weeks and everything worked fine .
have a look here
http://i51.photobucket.com/albums/f3...k/Image113.jpg
have a look here
i still have my pcv hooked up and i have a valve cover breather..the actual kit the screws in to the old cap and then it has indentions to stick the filter in there..i have never had any oil pressure problems
Originally Posted by FRCstruggla
Actually yes. My car. On both the 346 previous and now the 408. I am running SD no maf and have an open air breather on the valve cover, and the valley PCV routed through a closed catch can back into the intake. My oil pressure is rock solid in all situations.
One thing I did notice is when I first put a breather on the drivers side valve cover nipple (normally capped) it didn't vent and pushed up the dip stick. When I put the breather on the passenger side it vented fine under WOT and has worked for many miles. Not sure what your friend did.
I'm getting pressure build up as well. My dipstick pops out and shoots a little oil on my valve cover. I'm running about 12lbs of boost. I have a breather on the passenger side valve cover and a cap on the driver side valve cover. From what I've read, you shouldn't have a breather on with the pcv setup? Should I cap the passenger side valve cover that has the breather, just like the driver side?
Make sure your PCV valve is working correctly and not gummed up. Your PCV valve should be setup so it allows air to flow from the PCV system into your intake, but not let air from your intake into your PCV system. If there is air pressure getting from your intake to your crankcase via the PCV system (oil dipstick tube popping out), then it sounds like your PCV valve is bad.
Otherwise remove the system and cap off the lines to the throttle body and run a breather in the valve covers.
On my LS1, I'm doing what someone on the first page mentioned and connecting both valve covers via a 3/8" vacuum hose and then running a breather on my oil fill cap.
