what is the stock preload?
Thunder said .060-.070 w/Heads/Cam Cars and stock is .080-.090
Texas-Speed said .020 (they also recommended to use Lunati Specs)
Lunati said .030-.040
AFR said .100
I got ranges from .020 all the way up to .100. I think I'll go somewhere around .030-.050 based on the answers I received.
Id do exactly what you have planned....
Thats just it there is a WIDE variety of what the experts consider properly setup. Sounds like personal preference to me. Id go with the lifter manufacture Lunati.....
.020 longer than stock.
That being said, in stock headed applications, many vendors suggest you leave the .030 less preload there to help combat lifter pumpup at higher rpms, although im not sure now the extra preload supposedly helps this.
This is specific to non adjustable rocker systems with stands (LSx in our case)
Stud systems adjust both geometry AND preload via p-rod length (like Comp Magnums)
There is a .00x variance amongst a set in every motor.
Now a parameter rarely thought of is the measuring device and that can account for some reading variances besides actual ones.
I did it three times and each time got a measurement of .150"
I was very surprised it was so much, but the engine was running fine like that.
Personally I wonder why so many people remain stuck in the world of non-adjustable rockers when it is so easy to convert over to adjustables & guide-plates. That way you can easily get swipe and preload correct by simply using the right length pushrods.
1. "dial indicator" measured preload = 0.163"
2. scribe pushrod loaded/unloaded and measure with calipers preload = 0.160" (as best I could eyeball)
Thats my take on it anyway.
The internet is great for opinions. Most opinions I've read on this site say it CAN affect power.
Not knocking what your saying, just pointing out the opinion is on both sides of the fence.
But if too much preload can hang valves open ( to the point the car won't start and it backfires through the intake ) then wouldn't it make sense that a little less than that ( enough for the car to run ) would be down on power too?
