Normal Oil Pressure Readings
Old Mar 11, 2006 | 04:42 PM
H8 LUZN's Avatar
Default Normal Oil Pressure Readings
Just to be on the safe side,
What are the normal oil pressure readings in a stock LS1 w/ 5w30?
Reading off of the stock gauge...
(i tried a search but it didnt narrow it down any)
Old Mar 11, 2006 | 09:19 PM
marv's Avatar
Off the stock gauge, I typically see 60psi at startup and when I get on it pretty hard....
Once warm and at idle or cruise, I typically see ~40psi....
Running 5W30 Mobil 1
Old Mar 11, 2006 | 10:03 PM
kenp's Avatar
I have slightly over 40 warm at idle and slightly over 60 cruising at 1500 rpms. 5W30 synthetic.
Old Mar 11, 2006 | 10:24 PM
pla-tym's Avatar
40 lbs @ idle warm... 60 lbs @ highway speed 70mph... today
5w30 Mobil 1
Old Mar 11, 2006 | 11:35 PM
brad8266's Avatar
if I sit idling for while and the engine gets hot, mine goes slightly below the 40 line. Hot at a cruise 50-60
Old Mar 11, 2006 | 11:36 PM
brad8266's Avatar
I read somewhere 10psi is needed for each 1000 rpm's as a general rule
Old Mar 12, 2006 | 12:10 AM
oange ss's Avatar
that is the recognized minimum
