Blue smoke?
Old Mar 13, 2006 | 12:46 PM
RealLiveMD's Avatar
Default Blue smoke?
I know this is an LS! site, but my other car is a 2003 Camry with only 59000 miles. For some strange reason it now has blue smoke and this thing has been babied. It is due for for an oil change. My question, "Is there anything else that can cause blue smoke at start up other than what I've heard as bad rings from excessive wear.
Old Mar 13, 2006 | 01:40 PM
GuitsBoy's Avatar
I say its valve seals or anything else that could be leaking into the cylinder while the car sits overnight. Rings would probably smoke more under power than at startup
Old Mar 13, 2006 | 02:41 PM
RealLiveMD's Avatar
yea, this is crazy cause I bought the camry figuring my GM wouldn't last that long.
Old Mar 13, 2006 | 04:15 PM
marv's Avatar
I also would say valve seals. I have a 96 Avenger with 276K on the clock and it does the same thing. Now mine has an excuse due to mileage, but I wouldn't think a Camry with 59K would do that. My wife has a Camry with almost 59K on it, and it hasn't had any problems what so ever.
My Avenger typically does it upon start up, or if left idling for a long period of time. Usually quits after a mile or so.
Old Mar 13, 2006 | 04:37 PM
Rescue Ranger's Avatar
i had an accord, 91 that did that horribly at startup. valveseals were replaced and it was good
Old Mar 14, 2006 | 06:23 PM
RealLiveMD's Avatar
What about the pcv valve?
