Prc Stage 2 Dart Heads
With bigger than stock valves the Trqr V2 should be on a 113+0, then it will clear up to 2.04
With the torquer cam (1st generation profile) 233\233 .595\.595 112 +2 and the 225 dart heads with 2.02 1.60 size valves is there going to be problem or will I have to notch the stock pistons..
The standard Stage 2 CNC ported dart heads we ship use Darts valve job.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
