Prc Stage 2 Dart Heads
Originally Posted by just-a-z
I turned the motor over by hand and everything went smoothly and didn't hit. I am not sure the exact # and I also have my pistons slightly eyelashed on the intake side do to a lot of over-revin in my last set-up
Originally Posted by DROPTOPLS1
Just got off the phone with Jon heads were milled .015.I am going to have to notch the pistons.
When I spoke to them today they said if I sent them back they would sink the valves.I was told that will mess up the flow and I already waited almost 2 months to get these heads so I don't want to do that.
When I ordered them I asked to have them milled but then I changed my mind and asked them not to but they still ended up getting milled.
I am running the PRC Darts and the MS3 with stock gaskets and have good PTV. Maybe your heads are milled.
#32
I was told that sinking the valves effects the way the head flows.I don't think you will notice that or the lower compression.How much clearance do you have cause if you are hitting the piston I don't think .040 is enough.
