Head Bolts with milled heads?
Old Mar 15, 2006 | 04:25 PM
algws6's Avatar
Default Head Bolts with milled heads?
Can I use stock GM Head Bolts if i mill my heads .030 and use .045 gaskets without the risk of them bottoming out? or should i step it up to studs? FYI this is on an 04, i think the bolts are shorter.
Old Mar 15, 2006 | 09:40 PM
algws6's Avatar
tttttt
Old Mar 16, 2006 | 07:24 AM
GuitsBoy's Avatar
Youre probably fine. I used GM bolts and milled .040 without incident.
Old Mar 16, 2006 | 11:36 AM
Mirek's Avatar
I had the same concern. I milled .030 and used the .045 gasket and it is fine with the stock TTY bolts.
Old Mar 16, 2006 | 11:48 AM
algws6's Avatar
Thanks guys.
Old Mar 16, 2006 | 12:18 PM
wicked z28's Avatar
What About Ls6 Heads Milled 55 Thous. With Cometic .45 Gaskets on a 408 lme iron block.should i get arp if so which ones
Old Apr 5, 2006 | 03:36 PM
Azar's Avatar
LS1TECH Sponsor
Good question...I just bought heads milled .05 but I'll be using stock gaskets...which are .54 thick??
