Would it be a bad idea to supercharge my application?
With the mods listed in my sig, I'd kind of like to get even more power... :-\ I kinda have the modding disease, where too much is never enough
I'd prefer to not slap the nitrous on if I could get away with a supercharger. So I understand that I have high compression cylinder heads and what not, but i'm curious if I could still run a supercharger and maybe just run lower boost and be safe? Also, if I did this, how much power would I expect to gain?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
your compression is too high for a FI setup...i'm no expert, but you'd probably only be able to run a max of 3 psi in order to still use pump gas - at that point, you'd really only be offsetting the parasitic loss from the blower with very little gains
I'm only running 10.9 CR right now, and I'd be fine running 5-6psi. ECS recommended to replace my 228R cam w/ a ZO6 cam (too much cam), replace my 63cc heads for some 70cc to get the CR down, and I'd be fine. Andy said the cam would be fine, but it was a little big; And, as far as the heads he said I'd be fine w/ 5-6psi. The thing that gets me is the price for all the installation. I'm assuming installation to replace my cam and heads would be about $1500, then for the SC another $1000 on top of that. Then there's maintence issues, replacing belts yearly, replacing the oil every 3000-6000 miles, and the worry of everything staying together. I'm still on the edge, not sure which way to go.
Here's my problem, A&A's kit is $5500, I've got a 90/90 setup I could sell that hasn't gone in (1150), #30 inj(250), TR55s(50), and Double roller timing chain(100) . So it'd actually come out to about $4000, but then the extra for install puts it right back up there.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
it just sux, because I paid so much for my cartek heads... but I just can't quench my insitiable thirst for more speed
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
