Check out this 228?
Old Mar 17, 2006 | 07:15 PM
UltraZLS1's Avatar
Default Check out this 228?
This looks kind of interesting. What do you guys think of this cam?
Would it make good power for street/strip? I dont want to rev past 6500.
It uses the z-cam lobe profiles.
http://www.sdpc2000.com/catalog/3876...0-0600-113.htm
Its advertised duration is 290 @ .004....so I dont know how to compare the ramp rate. I know using duration @50 compared to gross at .006 can get you ramp rate. But in this case the ramp would be 62...and I know thats not right.
So how can I convert 290 @ .004 to what it would be at .006?
If the ramp ends up being between an xe and xe-r I am getting this cam
How do these base circles compare to the other cams?
Is .600 lift too much for a 228?
I am just looking for something a little different than everyone else.
thanks a lot, Troy
Old Mar 17, 2006 | 08:53 PM
Ragtop 99's Avatar
Looks like a crane cam. .600 lift is no problem for 228* just make sure you have good springs.
Old Mar 17, 2006 | 09:42 PM
blue28's Avatar
Thumbs up
It's a lot like my cam, only mine is 122 lsa, be sure to get it tuned when I first put it in it always quit at stoplights and other stops if I didn't power brake it but after I got it tuned it sounds like a pro stock drag car and really works well.
Old Mar 17, 2006 | 10:01 PM
UltraZLS1's Avatar
Yeah it is a crane cam. They are custom ground for sdpc with the z-cam lobes from crane..which from the sounds of it are supposed to be compareable to other high ramp cams like futral and xe-r.
Ive got patriot duals good for .650 lift.
