Clean Carbon Off Top Of These Pistons???
Originally Posted by lowchevy2go
i was wondering he same thing but i scraped a little off and a few of the shavings went between the piston and the cylinder wall....is that going to cause a problem??
Slowly rotate the motor, coat the cylinder walls with oil, and then rotate some more. All the junk will hang up in the oil on the cylider walls and you can clean it out.
#33
Originally Posted by thunderdan74
unless you're going to pull them out, I'd leave them alone. You don't want to knock that stuff off the top of the piston and get it worked into the rings.
#34
I've got a question guys..
I just started cleaning my pistons.. I've got one looking verrrrry nice.. Anyway, my pops is helping me on the H/C swap and he asked why I was doing that when they are just going to be dirty again in 6 months..
So.. now I have a very nice #2 piston and the rest are "stock" dirty..
I don't mind cleaning the other 7, but my question is.. would it cause any problems to just put it back together with 7 dirty pistons and 1 clean piston?
