possible the stupidest problem ever....
Old Mar 19, 2006 | 07:26 PM
dirty2kTA's Avatar
Default possible the stupidest problem ever....
im really not sure that this thread belongs here, but oh well....
ok i pulled my motor and it went back in w/ new heads and cam just fine. the transmission was a pain in the *** though. it was twisted and didn't wanted to come foward. i used the bottom two bolts that bolt the pan and the one at top the kinda pull the trans foward as i tightened them down. when i everthing was done i cranked the car. everything was fine is except i had a hell of an oil leak. i assumed it was the pan gasket sense i didn't change it. i bought another and pulled the pan back off. when i did this i found that the drivers sides rear lip of the pan was broken. it was an inch piece which included the the bolt hole. i bought a new pan and installed it. i had the same freakin probs w/ getting the trans untwisted. anyways after stuggling, it went together. cranked it up.... same leak.. pulled it back off... same f*ckin piece of the lip was broken off. why is my oil pan doing this???? my plan this time is the not put any of the rear bolts in the pan until the trans has the bolts bolted to the motor. maybe this will releive some stress. what do yall think.
Old Mar 19, 2006 | 10:02 PM
dirty2kTA's Avatar
ttt
no comments at all????
btw this isn't my first motor that i completely torn down and put back together. and im not crazy like a few friends said when i called them....
Old Mar 19, 2006 | 10:06 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
This is an LS1 correct?
Old Mar 19, 2006 | 10:27 PM
dirty2kTA's Avatar
thats right...
2k trans am stock a4 stock block vig 3200 h/c ect...
Old Mar 19, 2006 | 10:37 PM
ЯєŧąяĐ Єlˇmˇиąŧřя ™
When you say twisted....is it ever lining up with the dowel pins without some brute force?
Old Mar 19, 2006 | 10:42 PM
dirty2kTA's Avatar
i took some effort to get the trannie on the pins... i lowered it serveral times and adjusted it... but when it went on the pins i tightened the bolts to pull it foward... one time the stall was in a bind.. but i got that worked out and used the same method as before.
Old Mar 20, 2006 | 01:01 AM
eallanboggs's Avatar
Cast aluminum can only take so much abuse.
Old Mar 20, 2006 | 01:12 AM
SUX2BU's Avatar
you shouldn't use the two bottom bolts to "suck up" the tranny. is that what you did?
Old Mar 20, 2006 | 12:29 PM
dirty2kTA's Avatar
yes i did.. im thinkin thats where my stress came from?
