MS3 p to v ?
Old Mar 21, 2006 | 10:52 AM
CraZee ZO6's Avatar
Default MS3 p to v ?
What is the ms3's piston to valve clearence?
Stock ls6 heads.
Old Mar 21, 2006 | 10:55 AM
Kraest's Avatar
You'll have plenty on the stock head.
Old Mar 21, 2006 | 11:08 AM
CraZee ZO6's Avatar
How about on aftermarket heads (AFR,ETP)?
Do plan on doing heads later on.. Not sure if aftermarket or if I should just get my stock ls6 heads massaged...
Old Mar 21, 2006 | 05:47 PM
Kraest's Avatar
You'll have plenty on any of those heads. Once you start milling them and/or changing the thickness of the head gasket is when you'll need to start measuring PtV.
Old Mar 21, 2006 | 11:19 PM
35thls1ss19's Avatar
i would not say plenty anytime your doin a cam that big you should check pv. I am in the process of puttin darts on my ms3 and the valves are hitting i just sent them back to tsp bc they are not much smaller the stock heads so they should clear.
