motor mounts broken?
Old Mar 21, 2006 | 10:26 PM
dirty2kTA's Avatar
Default motor mounts broken?
have any of you guys ever broken a motor mount? i just put the motor back in my car. its not bolted to the trannie, but with the bolts tightened in the motor mounts, there is 2-3in of front to back play. the motor will rock back and fourth (foward of the car to the back) not side to side. do i have a broken mount?
Old Mar 21, 2006 | 10:30 PM
BackinBlack02SS's Avatar
Unless it will rock very easily, you are fine. Without the engine mounted to the tranny which is mounted to the crossmember, it will have some slight front to back play.
Old Mar 21, 2006 | 10:52 PM
dirty2kTA's Avatar
thanks
i think im going to go foward with the assembly. it wont be that big of a hassel to change them if they are broken anyways. what should i watch for? vibration?
Old Mar 23, 2006 | 07:38 PM
camaro608's Avatar
finish and when you start the car and the motor shifts when you put in gear you have a problem
Old Mar 28, 2006 | 07:32 PM
98ssinar's Avatar
I want solid motor mounts is that a good idea?
Old Mar 28, 2006 | 08:45 PM
Beast96Z's Avatar
If you want your fillings to fall out of your teeth.
