I have a tapping noise, long read
Old Mar 25, 2006 | 10:21 PM
c5dream's Avatar
Well I removed the heads for the fourth time again. I clearanced the pushrod holes a lot more this time. After getting all back together and started it up it was nice a quite much better, but after it warmed up noise came back but not as bad as before. So the holes need to be clearanced even more which I am not going to do. I have decieded to ditch the PP roller rockers and go with a more stock rock/pushrod setup. I found some Yella T rockers arms that use stock geometry and stock pushrod lengths. Wish me luck for the 5th time.
Old Mar 26, 2006 | 08:17 PM
c5dream's Avatar
I put my stocker rocker arms and pushrods in today to see if it quiet things down. Well it pretty much sounded like stock which is good. I had a slight tap but that probably because I need more preload so need slightly longer prod.
Old Mar 28, 2006 | 07:40 PM
mailman2000's Avatar
are you sure the 918 springs are enough thought you needed dual springs like 921's
