Help No Oil Top End '99 T/a
Old 03-22-2006, 02:38 PM
martyp's Avatar
Default Help No Oil Top End '99 T/a
Hi, I'm new to this. My problem is, that I'm not getting any oil to my top end. Pulled the valve covers & ran it, nothing. Showing 40-50 # on the dash gauge. It's a '99 T/A, with 62K showing. Car sat for 1 1/2 yrs. I've been hearing that sitting will make the oil settle. What can I do to prime the lifters, to see if that will help. Any help, would be appreciated. Thanks, martyp
Old 03-22-2006, 06:04 PM
martyp's Avatar
Is anybody out there ?
Old 03-23-2006, 07:33 PM
camaro608's Avatar
pull out the push rods and clean them out then put them back in. if you still have no oil then you probably have clogged lifters.
Old 03-23-2006, 08:31 PM
BackinBlack02SS's Avatar
Was the car hot when you did this? How long did you let the engine run?
