AFR205 or ET215
Old Mar 22, 2006 | 09:20 PM
lhaitzss's Avatar
Default AFR205 or ET215
Been searching for awhile and have a hard time deciding on what head to get. Everbody seems to like both. But what will be the best set up from the people htat have tried first hand. This is what I already have, Ls6 intake, asp pulley, 4.10 gears, lid, long tubes, and ported tb. They seem to be around the same price. Also my bottom end is stock. Maybe in the near future I may upgrade to bigger CI. But for now the 346 will do. Also i'm kind of stuck on the f14 cam to go along with the setup. if somebody thinks differently please speak up. Thanks
Old Mar 22, 2006 | 09:53 PM
Ksett's Avatar
I don't have my setup completed yet but I have everything ordered and I'm using an F13 cam. I went with the AFR 205's over the ETP 215's just because nobody has the ETP's and people have been waiting for weeks to get theirs. I think either head will provide similar results if they are setup for the same compression IMO, but who knows (not enough data on the ETP's yet). One thing I like about the ETP's is that I would not have to flycut to run 11.25:1 compression with the F13 and that is what has to be done with the AFR's.
Old Mar 22, 2006 | 10:46 PM
eamador11's Avatar
Get AFR they are the best.
Old Mar 22, 2006 | 10:52 PM
joshp14's Avatar
There are guys running AFR 205's with 11.2 compression w/o flycutting.
Old Mar 22, 2006 | 11:16 PM
SScam68's Avatar
What was the lead time for your heads?
Old Mar 23, 2006 | 06:00 PM
Ksett's Avatar
How much was shaved off the head and what size gasket are you running?
Old Mar 23, 2006 | 06:02 PM
Ksett's Avatar
TSP had a set of AFR's in stock when I ordered a couple weeks ago.
Old Mar 23, 2006 | 06:34 PM
Patrick G's Avatar
LS1 Tech Administrator
Thunder Racing had AFRs in stock last time I checked.
Old Mar 23, 2006 | 07:06 PM
JEB99TA's Avatar
Mine's 11.2-11.2 compression and I've bounced ny forged motor past 7000 rpm several times. AFR's are great ... don't know anything about the ETP's, so, can't really comment on them.
Old Mar 23, 2006 | 07:43 PM
FULTILT's Avatar
I'm one of them, F13 on 112+2 with AFR's at approx. 11:1, tons of valve clearance on both intake and more importantly the exhaust side. Go with the AFR's just because you will be guaranteed good results, I know there are other good heads out there but results vary with them, rarely do they vary with the AFR's. I hit 455 rwhp, 421 rwtq, with 90/90 set-up! Also remember, check your valve clearances with EVERY combination no matter what cam you use. Tony Mamo should hire me to be AFR's pr guy, that is how much I like AFR's heads. By the way, I am running stock MLS gaskets.
That f14 probably will be tight on your p-v clearances, also remember that a mechanical over-rev will bend valves in a STOCK motor and there is nothing to remedy that other than good shifting. I bent 8 valves on my stock 2000 c5 so I know first hand about it. Also, the best valve spring money can buy is never a bad thing.
Old Mar 23, 2006 | 08:03 PM
Ksett's Avatar
How much was shaved off your heads?
Old Mar 23, 2006 | 08:14 PM
DocEwww's Avatar
Im partial to ETP because of the added vavle clearance of 11* heads.
Old Mar 23, 2006 | 08:20 PM
SlickVert's Avatar
Both are great heads, the AFR have more then proved them self as a top performer.
ET is new, but has all the right stuff to make it one of the best LS heads on the market, also the ET 215 will give more PTV with more compression then any other head out there right now.
I also like the FM14 cam, either head will make a killer set-up.
Bob
Old Mar 23, 2006 | 10:32 PM
lhaitzss's Avatar
Thanks for all the suggestions.
Old Mar 23, 2006 | 10:39 PM
mr2guru's Avatar
What kind of valve drop on the 215s vs. stock vs. AFR205s
Old Mar 24, 2006 | 07:03 AM
Patrick G's Avatar
Gentlemen, let's keep this a technical discussion. Flaming and childish behavior on this board will not be tolerated.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 24, 2006 | 09:25 AM
02ZOh6's Avatar
Good technical info. here.
Old Mar 24, 2006 | 10:33 AM
FUN LS1's Avatar
Huh?! Did you delete the Flaming post? I didn't see anything remotely out of line above. Hard to figure out why someone would flame a suggestion for either of these heads...
Old Mar 24, 2006 | 10:45 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
The AFR 205 has close to .180 valve drop (about .015-.020 more than stock 243 casting) but the 11' valve angle of the ETP head will certainly provide more.
Tony M.
Old Mar 24, 2006 | 01:41 PM
Patrick G's Avatar
Yes I deleted the flaming posts. Don't need that kind of behavior on a tech board.
