Cherry picker flipped over!
Old Mar 23, 2006 | 12:15 PM
cjs27410's Avatar
Pull the balancer off and put a dial indicator on the crank snout. First check the run out then check the end play. That will give you some more info.
Old Mar 23, 2006 | 12:30 PM
MrDude_1's Avatar
BINGO!!! we have a winner!
rather then guess if its bent, get a dial indicator... spin the crank with it on there and SEE if its bent.
then check the thrust bearing, also with the dial indicator.
you can do all this in the car...
btw, assuming you dropped everything on it, fully assembled, just right to put the most breaking force on it....... id still bet you $50 the crank or motor was not damaged.
its probly just the balancer.
if you want to be smart and sure and check everything, do what cjs27410 and i said... that CHECKS everything that could be damaged... no need to disassemble the entire motor.. LOL.
Old Mar 23, 2006 | 01:42 PM
FunkyTownFBody's Avatar
Yeah I agree, establish that at least the crank is damaged before you get someone ripping it apart. You should have no problems using the dial indicator without pulling the engine from the vehicle.
Old Mar 23, 2006 | 05:52 PM
98ssinar's Avatar
I am going to have to replace my ring on my LS1 so I think I am getting new piston, rods, and crank. will I have to rebalance it. If so how do you do that? This is my first time tearing a engine all the way apart so any help will be great.
Old Mar 23, 2006 | 06:44 PM
99ssleeper's Avatar
no kidding, thats probably the first thing the engine builder would do anyway.
it's a lot easier to pull the balancer and set up a runout gauge than pull the engine and have him disassemble the whole thing.
Old Mar 23, 2006 | 07:06 PM
BAKED's Avatar
Me and one of my friends hit a tree doing around 50 mph or so (I'm not real sure, we were passed out) and it looked like the crank was bent but it had only kicked the balancer sideways. We pulled it out of the car, fixed the balancer and dropped it in my dads station wagon. It runs great, he drives it to work every day. Oh yea, we also added a nitrous kit to make up for the weight of the wagon.
I say check it before you spend all that $$$$$$
Old Mar 23, 2006 | 10:11 PM
XtremeDime's Avatar
110% is not possible. if there was a such thing as 110% it would be 100% still. 110% is unattainable.
Old Mar 23, 2006 | 10:13 PM
XtremeDime's Avatar
ill ******* kill anyone that does that.
Old Mar 23, 2006 | 11:47 PM
Greg Fell's Avatar
yeah, what the devil?
Old Mar 24, 2006 | 01:06 AM
VORTECFCAR's Avatar
man....
at least it wasn't a school bus
Old Mar 24, 2006 | 01:28 AM
cantdrv65's Avatar
Post
Kill what?
Old Mar 24, 2006 | 05:02 AM
  #32
flyin red TA's Avatar
Oh well...his user name says it all.
Old Mar 28, 2006 | 03:32 PM
  #33
XtremeDime's Avatar
ya thats true. wat a **** tard.
Old May 2, 2006 | 02:18 AM
  #34
SStolen's Avatar
UPDATE: Well, I got my engine back last week. I still can't run it because now I am missing the exhaust housing to my turbo (it never ends!) Anyway, my builder gave me a heluva deal. The crank WAS bent, 30-thousandths, and it ruined one bearing, the first one, where it cut into it from being bent. Unfortunately, I had to buy a full set as I couldn't order just one. My engine builder checked the entire engine and the mains and they are fine. I paid $190 to FIX the crank under the deal that if it couldn't be fixed I would pay nothing. The machinest said it was fine and my engine builder rechecked it as well and assured me that it was fine. He feels the head gaskets are fine as well so I got by with only $500 for a rebuild AND a full set of coated main bearings AND the crank machine work! I basically only paid $200 for the labor to rebuild the motor. I have to say I am very releived. He will defenitely be geting a x-mas card from me this year. lol. Thanks to all for the advice.
Old May 2, 2006 | 07:21 AM
  #35
GuitsBoy's Avatar
Good deal. Sounds like a great machinist / builder.
