Procedure For LS1 Rocker Arm Install?
If you study the chart I showed in Post #20 against the GM procedure, you'd see that's not true, and every rocker that's torqued down while following the GM procedure has zero spring pressure on the rocker arm.
But the GM procedure puts the rocker you're torquing down with the lifter on the cam base circle and the valve fully closed.
I wasn't sure about it myself until I made up this chart (attached) that verified the GM procedure does indeed put them all in the fully closed position when you torque them down. The chart shows this when you compare it to the GM procedure to correlate it all together.
With any rocker setup with intake and exhaust on a single shaft they must be torqued while both valves are closed, with GM setup this isn't an issue.
On a side note - if anyone doesn't believe the GM procedure works for the independent GM rocker setup, after all the rocker arms are torqued down, put the motor in the condition the procedure calls out. You will see that you are able to rattle the lifters for those valves that are supposed to be un-loaded during the tightening sequence.
I thought that this info would be helpful.
Moderator "JOSEPH" sent this to me as a reply to my question about finding TDC #1. on the LS1
Being old-school, I was used to lining up the dots on crank & camshaft gears, then setting rockers for #1. Following this procedure, I couldn't figure out why the valves on #1 were not completely closed. I thought that the vendor had sent the wrong cam, or that there was an error with the cam grind.
As follows.....Thanks, Joseph!
Glenn,
I'm glad you found my info helpful, not many people know the valve events for all 8 cylinders and when they happen. You would naturally assume with the dots aligned it would be the firing position of cylinder #1, when its actually the start of the intake stroke as far as the piston/intake valve is concerned. With the dots aligned cylinder #6 is the one to set preload/lash/ or for installing rockers.
Each 90* (720* / 8cyl = 90*) on the crankshaft gear is another cylinder firing, while each 45* (360* / 8cyl = 45*) on the camshaft gear is another cylinder firing. Having the timing cover off helps to watch the sequence.
Here's a copy/paste of a manuscript I'm working on that may help also:
Quote:
Originally Posted by Joseph
LSX Firing Order 1, 8, 7, 2, 6, 5, 4, 3
TDC Cyl. #1) Camshaft dot at 12:00 / Crankshaft dot at 12:00
TDC Cyl. #8) Camshaft dot at 1:30 / Crankshaft dot at 3:00
TDC Cyl. #7) Camshaft dot at 3:00 / Crankshaft dot at 6:00
TDC Cyl. #2) Camshaft dot at 4:30 / Crankshaft dot at 9:00
TDC Cyl. #6) Camshaft dot at 6:00 / Crankshaft dot at 12:00
TDC Cyl. #5) Camshaft dot at 7:30 / Crankshaft dot at 3:00
TDC Cyl. #4) Camshaft dot at 9:00 / Crankshaft dot at 6:00
TDC Cyl. #3) Camshaft dot at 10:30 / Crankshaft dot at 9:00
If you have that and the timing cover off you don't even half to measure how far you turned the engine over, just line up the dots to the correct orientation and install.
Thanks,
Joseph
Glenn,
Thanks,
Joseph
gMAG - good info you passed along also if using the cam turns and marks as the indicator. Cam turns once for every 2 turns of the crank, so using the cam makes it every 45 degrees instead of 90 degrees of the crank to get the next cyl in the firing order on TDC.
#32
Glenn,
Thanks,
Joseph
Glenn,
Thanks,
Joseph
Thanks for posting this!
#34
2002 Corvette Factory Service Manual mentions nothing about Loctite on the rocker bolts. Guess GM changed their procedure along the way.
#36
Aloha,
I'm not saying what's rite or wrong, just saying thousands of folks have just tightened to 22 ft , rotate and recheck. Rotate and check just to make sure they all got torqued. Speed shops people I know and myself included. The ls1s have NON adjustable valve trains. Torque the rocker, and the lifter will pump up when car is started.
Just last week I installed my mayhem cam. Dot to dot, I tightened. Then just for **** and giggles, I turned the crank to 5 other positions, I checked all rockers everytime. The torque was 22 ftlbs everytime. My project turned out cherry again.
I'm not going to jump in and debate, just saying, the "set it and forget" method has worked just fine for thousands of projects.
#37
Aloha,
if the engine is rotated an even number of times, then some of the bolts will be at 22 ftlb and others will be at less than 22 ftlb...
I think this is why some people experience a few rockers coming loose.
#39
Aloha,
Hope that makes sense.
